Ugh!!!!!!!!!
I'm backing up "Inside man" and cannot successfully do it. I've done this before with other movies but am having no luck with this one. While walking through the steps everything is fine until I go to find my PSL file which was supposed to be created by the PSL2 plugin but was not. I receive the message that it was successfully created but when I go to access it it is not there. To be sure I didn't mislabel it I searched my HD for any .PSL file and found nothing. What gives?
Apparently, you're not the only one:
http://forum.digital-digest.com/showthread.php?t=55964&page=18#
About halfway down the page. My first recommendation would be the same: try RipIt4Me instead. BTW, are you up-to-date with the latest PgcEdit, PSL2 Plugin, FixVTS, etc, etc?Pull! Bang! Darn! -
Probably not, it's been a while since I had the time to mess with it. Where can I go to update?
How does a program go from working to not working? Haven't changed a thing, doesn't work. By the way, yes I've downloaded latest PSL2 plugin. Makes no difference.
Ripbot 1.14.6 is generating errors when loading a m2ts file
By playitagain_sam in forum Blu-ray RippingReplies: 0Last Post: 29th Dec 2009, 10:59 -
Premier Elements 4 "generating peak file" Problem
By AAC in forum EditingReplies: 0Last Post: 20th Mar 2009, 09:24 -
psl2 plugin download????
By clms in forum Newbie / General discussionsReplies: 4Last Post: 27th Jul 2007, 11:43 -
DGMPGDec plugin for AVISynth doesn't read MPEG file's audio
By Mark001 in forum Video ConversionReplies: 11Last Post: 9th Jun 2007, 19:07 -
how to prevent generating video and audio file seperately?
By mzhang in forum ffmpegX general discussionReplies: 1Last Post: 29th May 2007, 09:42
