Have anyone tried to use a Xenon processor based computer to encode SVCD....if so did it work with CCE and what speeds are we talking about....
(by the way I am not sure of the processor specs, but I just want to get the big picture)..
You're probably talking about a Xeon processor, but in any case I have a Dual (Pentium 4) Xeon 1.8GHz Prestonia system. I can give you times of various encoding processes but it wouldn't give you much of an idea unless you could run the same tests on your system and compare.
I used to do my DVD > SVCD conversion with various programs but lately I've been experimenting with DVD2SVCD. I'm using CCE 2.50 and so far its been working great. If there are any specific tests you'd like to compare to let me know.
-wintermute
<font size=-1>[ This Message was edited by: wintermute_cz on 2002-01-11 14:00:50 ]</font> -
Yeah ...you are right, I mean Xeon....but what times are we talking about for a normal 2 hour video???
Justa an estimate... -
Well, I would have to say it would be comparably slower than a regular PII since it lacks MMX, SSE, SSE2. And if I'm not mistaken, a lot of the software take advantage of these multimedia instruction set.
tinmancp, thanks for your input, but I thought the processor I can get my hands on (Intel Pentium III Xeon @ 700Mhz) would work as a normal PIII using MMX, SSE and SSE2 ....but is this wrong????
Yes, I believe the Xeon processors have the same capabilities (although SSE2 is a P4 thing, not P3). They are intended to be server processors.
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
new processor
By alintatoc in forum ComputerReplies: 6Last Post: 21st Sep 2009, 03:16 -
Xenon MKV Help Pls
By sikstik in forum Video ConversionReplies: 5Last Post: 13th Jun 2009, 12:50 -
Is it my processor?
By davej1983 in forum Software PlayingReplies: 7Last Post: 11th Jan 2009, 01:53 -
Processor
By Tom in HD in forum MacReplies: 1Last Post: 1st Dec 2007, 22:02
