I have a three disc, six sided box set that I would like to back up to 3 disc instead of six. I have Toast 7, MTR, DVD2ONEX and dual layer capable Pioneer burner (109). Is there a way to get 2 VIDEO_TS on to one disc and preserve both menus? Any help would be appreciated. I have never tried a dual layer disc but from reading here it seems as Verbatim Media is the only choice. Thanks again..
"Enjoy every sandwich" Warren Zevon
There is no way to make a DVD from multiple DVDs and keep the menus. That's because the videos on the DVDs must be reauthored into a new single VIDEO_TS folder. That reauthoring process creates a new menu to direct the DVD player to what's on the disc.
What Frobozz said
Also I wanted to point out that single layer DVD-Rs cost around 10-20p each, and dual layers cost at least 5 times as much. There's also the value you place on your own time - I'd highly recommend you just back up to 6 single layer DVDs.
TV must be ON to record to DVD? [SOLVED]
By remm in forum Newbie / General discussionsReplies: 9Last Post: 22nd Oct 2010, 00:48 -
How to record a DVD using a software?
By coxanhvn in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2009, 20:57 -
any way to record from TV to DVD recorder?
By thedriver2200 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 10th Jun 2008, 12:37 -
DVD Recorders (VHS to DVD Recorder then record raw footage and finalize)
By aeafisme23 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 16th May 2008, 13:39 -
Philipa DVD R85 upgraded to ff16k, won't record on 16x DVD+R
By chimpanzee in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Feb 2008, 11:22
