i need help on getting an audio to my mpeg.. i encode it to mpeg.. it was avi to mpeg...i used tmpgenc puls 2.5 it just didn't burn my audio..i can't remember what that audio program was saying i reboot my cpu....so i need help on getting my avi movie to a mpeg format (only the audio)
What format of audio did you convert from and to? If you are planning on making a DVD from the MPEG, then you would need AC3, MPEG-1, Layer2 or PCM audio. For just MPEGs, one of those would also be a good choice.
You can also process your audio separate from the video and mux it (Combine it back) the video after encoding. TMPGEnc usually creates MPEG-1, Layer2 audio. For DVD specifications, look to the upper left for 'WHAT IS' DVD. <<<<<< Or if you are creating a DVD, your authoring program may let you add it then.
You could also drop the before and after video into Gspot 2.60 and see what it says about it. The audio might be there and you can't play it or TMPGEnc may have not encoded it. Did you set TMPGEnc to encode both the audio and video, not just video only?
And welcome to our forums.
its a avi (mp3 audio) and i want to encode it to dvd which i did....i try the video and the audio one but the audio just didn't work so i was left with the movie only...i try converting it to a
(AC-3) which i think is the right format... -
It looks like you are dealing with a VBR mp3 audio. Tmpgenc wont get you any audio from this. Do as redwudz said. Load avi into VirtualDubMod and save wav for the audio. Afterwards convert this wav into mp2 or ac3 (Ffmpegui does it well). Finally set your .m2v file as video source and your .mp2 or .ac3 as audio source in your authoring app.
RegardsThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin). -
yes....thats the program i been looking for all this time....thxs so much.....
Help! How to convert mpeg-2 file with LPCM audio to Final Cut Pro?
By afireinside181 in forum Video ConversionReplies: 3Last Post: 31st Oct 2011, 18:59 -
Convert mkv to mpeg 2 audio delay.
By Mastertreetop in forum Video ConversionReplies: 1Last Post: 4th Jul 2011, 16:04 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
How do i convert MPEG audio to ac3?
By php111 in forum AudioReplies: 9Last Post: 28th Sep 2007, 16:13
