I'm having problems with some Sony DVD+R 8x (they're genuine Taiyo Yuden, I'm sure).
Media ID: YUDEN000 T02
The code on the inner hub: TG001162
It burns the disc *successfully*, but when I try to read it, there are no files!
When I use Nero CD-DVD Speed to check the disc, it doesn't recognize the media.
It's like there's no DVD+R in the drive.
I had 3 coasters...
I have burned Taiyo Yuden DVD+Rs before and everything was perfect.
My burner: Pioneer DVR-107D
Nero Burning ROM 6.3.0.0 (old).
Does anyone know what's happening?
What does DVDInfoPro show for unreadable discs? I had 8 out of 100 Ritek G05 which showed blank discs but only 0.03 GB free space, and those discs were simply bad. You should also update to latest Nero version which may help.
Sometimes burners get "stuck" and cannot read a disc, even ones it made, after it's been burning for a while.
Did you try the disc in other drives, or just that burner?Want my help? Ask here! (not via PM!)
Hi again!
I updated my Nero to the latest version (7.2.7.0.), but still have problems.
This time I couldn't burn the DVD+R successfully.
The error message: "Unable to recover TOC".
What does TOC mean?
Here's part of the log:
21:12:20 #24 Text 0 File WriterStatus.cpp, Line 116
<D: PIONEER DVD-RW DVR-107D> start writing Lead-Out at LBA 2102288 (201410h), length 0 blocks
21:12:20 #25 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
21:12:35 #26 CDR -1122 File ThreadedTransferInterface.cpp, Line 1943
21:12:35 #27 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1943
Could not perform end of Disc-at-once
21:12:35 #28 SPTI -1122 File SCSIPassThrough.cpp, Line 291
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1122)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x57
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0E 00 00 00 00 57
Buffer x0343b400: Len x20
21:12:35 #29 SPTI -1122 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x57
Sense Qual: 0x00
CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
21:12:35 #30 Phase 127 File dlgbrnst.cpp, Line 1730
Generating DVD high compatibility borders
21:12:35 #31 CDR -1122 File WriterStatus.cpp, Line 167
21:12:35 #32 TRANSFER -24 File WriterStatus.cpp, Line 167
21:12:35 #33 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 4x (5.540 KB/s) -
Table of ContentsOriginally Posted by MomijiIf God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Why does this error (Unable to recover TOC) happen?
What could be the problem?
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
Complex problem, extra some chpts from 2 dvd and combine into 1 dvd + menu
By Shihtzu88 in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2009, 08:09 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 03:26 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 21:37
