Think this is the right form. I did a couple of movies using tmpgenc saved .tpr file with all the settings correct. Then converting it with VFAPIConv-EN.exe making a pseudo AVI with the saved .tpr. Launched CCE 2.50 used the avi as input and encoded it. Works great on my computer but on the stand alone dvd player, the movie is stretched horizonally just a bit.
How can I re encode the final mpg (after multiplexing) to the correct aspect ratio? Which I was hoping to accomplish using the .tpr file from tmpgenc. If I bring in the file into tmpgenc the aspect ratio is 4:3 now instead of 16:9. If I were to do it now, wouldn't it just do the same thing?
<font size=-1>[ This Message was edited by: Kwulabear on 2002-01-11 12:44:12 ]</font>
Results 1 to 1 of 1
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
Video Encoding
By Datson in forum Video ConversionReplies: 12Last Post: 24th Jan 2012, 14:27 -
Encoding Video
By manicjonah in forum Newbie / General discussionsReplies: 8Last Post: 20th May 2011, 12:41 -
will a separate video card speed up video encoding?
By edong in forum ComputerReplies: 12Last Post: 21st Oct 2009, 18:37 -
New to video encoding.
By pickledpacman in forum Video ConversionReplies: 1Last Post: 25th Mar 2009, 11:39
