Ok, I made a DVD 3 times and when playing it on my computer it looks and sounds great. When I play it on a stand alone DVD player 3/4 of the screen has all of the video with 1/4 of the screen showing a mirror effect of the first 1/4 of the 3/4 of screen. Got it? Now when I went to make a copy of this DVD with CloneDVD, CloneDVD pops up a screen that states "Trying to repair defective DVD structure Please wait! First I used CopytoDVD 4 from VSO software to burn the folders from the created SVCD2DVD folders next time I tried having it use ImgBurn 2.1.0.0 and have the program SVCD2DVD burn it. Both times I got the same result putting it into a stand alone DVD player. The third time I went messing with the settings and burned another one with ImgBurn and I still have the same problem.
Thank You,
Dargonfly2337
Results 1 to 9 of 9
What was the source file type? SVCD? What is your DVD player?
ok can you attach your log for this run? (logs are kept in the "logs" folder under where you installed the program)
I'll see what I can come up with in the next three hours. Currently at work. Thank you for your prompt reply.
Redoing capture from box from scratch and doing over at a later time.
Thanks for the information. -
I think that I have found my problem.
The beginning of the first file was in 2 channel audio (Recap of previous season) while the rest of the file was in 5 channel audio (The actual episode). Cut out the 2 channel audio part (with VideoRedo Pro) and just kept the 5 channel audio part to make my DVD. The other 5 files (episodes) were also in 5 channel audio. Now ConvertXtoDVD works, SVCD2DVD works and TMPGEnc DVD Author works without a hickup.
Found this information with AVIcodec.
Excellent!
Great news!
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Problems using SVCD2DVD converted assets in DVDLab
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Apr 2008, 17:28 -
SVCD2DVD Audio problems
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 6th Mar 2008, 11:53 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 10:35 -
SVCD2DVD 2.5 Problems
By mistalcote in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Aug 2007, 04:31
