Hi I have a Compro Video Mate gold tv tuner card but I am not satisfied with the software that came with the card. When I want to record something with a good quality I need to use the DVD option that has 6000 kb/s .This gives me a large file. I need something that will allow me to capture using a codec’s like Xvid that will give me the quality but not the quantity of the kb/s thanks.
I don't know your capture card.
There are plenty freeware programs, that allows you to capture to avi using codecs like xvid/divx, jpeg, etc: Virtualdub, Virtualvcr are the most freeware popular. For direct mpeg 2 capture, mainconcept pvr or the mainconcept encoder, if you have a good CPU (~3Ghz) is a nice choice. For freeware, I don't know any solution (maybe a plug in on GBPVR may do the trick, but only for bt based cards)
Which codec is the best for capturing VHS?
By aaxpers in forum Capturing and VCRReplies: 2Last Post: 27th Jun 2011, 06:45 -
Need basic info on Simple profiles when capturing video with XviD codec
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 21:54 -
Use a software codec when capturing with an ADVC300?
By timothyd_1975 in forum Capturing and VCRReplies: 22Last Post: 15th Jun 2009, 23:06 -
Best compression codec to use when capturing 720p video?
By Mysteriouskk in forum Capturing and VCRReplies: 3Last Post: 24th Nov 2007, 23:51 -
Which Codec is the Best for Capturing?
By rocknico100 in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 20:47
