I have a Full Feature movie in a Quicktime AVI format that I want to Convert/Burn to a Single Layer DVD so it will play on any Standard DVD Player ( Well at least mine because it's pretty new and I know it will
play + or - blank DVD's with no problem )
Also the Audio track needs tweaking with a equalizer if possible because the sound is kinda flat
I have the following software on my G4 -
Toast 7.1, Popcorn 2.0, iMovie 5.0.3 and Apple DVD Studio Pro 2 ( I don't want to install this one if I can use the programs I already have loaded on my Mac if possible )
Also Audio Hijack Pro 2.6.7 if that will help with the Audio Track ?
G4 Gigabit 450x2 / 1 GB PC133 / WD80GB 8M cache x3 / Tiger 10.4.7
Try playing the AVI in QuickTime Player. If video and audio are good, then Toast can convert the AVI without any additional steps. Just drop the AVI in Toast's video window.
The Video is fine when playing in Quicktime, But the Audio is way to low and Flat/Lifeless.
Can I run it through another software to do something about the Audio Quality ? -
You can demultiplex the audio and video tracks with the tools included in D-Vision or ffmpegX (you can also export the audio track to aiff with the "export" tool in Toast 7),Originally Posted by Blueimac
then process/filter the sound with any audio soft (Amadeus II, iMovie... ),
then re-export the track to the desired format (MP3 or anything else),
then re-multiplex the resulting audio with the video track (with D-Vision or ffmpegX).
Finally, check if everything is still in sync, and export to DVD with Toast 7.Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
AVI mono movie too big to burn on to single layer DVD-other options?
By nzdreamer55 in forum Authoring (DVD)Replies: 7Last Post: 29th Apr 2011, 14:45 -
Movie to big for screen??
By bunkerhill in forum Newbie / General discussionsReplies: 6Last Post: 4th Jan 2010, 06:09 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:18 -
Using My Big Screen For Pc Monitor
By Robspace1 in forum DVB / IPTVReplies: 11Last Post: 13th Jun 2007, 13:55
