Hi,
What and how will you be able to save offline web sites and all the links that go with that web site also to where your able to go back and view the whole web site and all its links if you where offline? Please and thank you!
In Internet Explorer (since you have XP according to your computer info):
File menu - Favorites - Add to Favorites
Check the "Make available offline" box
Click the Customize button and follow the instructions.
It may not work properly for all websites, depending on whether the website restricts robots and other things that can be used to steal someone else's pages!John Miller -
Hi,
Thanks sooo much! How would you do it with netscape because that is the web browser I use more? Thanks soo much! -
I'm sorry - I don't use Netscape...hopefully someone else can answer.
John Miller -
For Firefox (and maybe netscape too, who knows): download and install the "Scrapbook extension". This allows a very flexible way to capture any webpage in a scrapbook (which can even be edited, highlighted, etc). EXCELLENT TOOL!!!
Viva Linux! -
Httrack will spider and download the website for you with all the contents, and it's free.
what conversion programs do most web sites use
By Magpye in forum Video ConversionReplies: 6Last Post: 24th Aug 2011, 10:53 -
save a flash video and re-play it offline on Mac
By lilly333 in forum Video Streaming DownloadingReplies: 6Last Post: 25th May 2008, 10:20 -
Removing a web sites name from clips
By prorodeolover in forum EditingReplies: 1Last Post: 13th May 2008, 23:36 -
ARE there web-sites that lease, and i join and use their software
By Lennoxtown in forum ComputerReplies: 1Last Post: 13th Aug 2007, 06:55 -
Could you recommend a web-sites with LCD TV reviews?
By fat32 in forum DVB / IPTVReplies: 3Last Post: 19th May 2007, 14:05
