    Sep 2006
    what do i do next with dvdshrink to make the files fit to burn on nero? i am having a problem with dvdshrink. i download it to my documents folder and i get an extension message? is there a way i can save it directly to dvdfabdecrypter to bypass all of the alerts i am getting?
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Where did you download DVD Shrink from?
    To shrink a DVD you need 3 free programs -
    DVDFabDecrypter - Use this to decrypt the copy protected DVD to your hard drive
    DVD Shrink - Use this this to shrink your DVD that you decrypted with DVDFabDecrypter
    ImgBurn - This will burn the two folders that DVD Shrink has created
    Read the many, many guides on this website. Click on the links in this post and you'll see all the guides listed under the software description.
    He's a liar and a murderer, and I say that with all due respect.
  3. When I use DVD Shrink, I use the drop down option to burn the resulting file as a .iso image file. Then I open that file with Roxio Easy CD DVD Creator 6. It will burn the .iso to a fully functional DVD. But you can probably use another program other than Roxio. My point is, I like to shrink the files to a .iso image file and go from there. That always works for me.
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    You can also burn ISO's with ImgBurn but i'm trying to make it as easy as possible for jrswifey6264, he/she is confused enough as it is !
  5. Disgustipated TooLFooL's Avatar
    Feb 2004
    Opium Den
    have you read anything here before you started posting?...
    https://forum.videohelp.com/viewforum.php?f=20
    I am just a worthless liar,
    I am just an imbecil
