This may be a stupid question, but my friend has the JVC GR-HD1 and I noticed it allows you to shoot video in HD, SD, or DV. What is the difference between SD and DV? I thought they are the same thing. Thanks.
Jeff
According to the information at B&H Photo:
In other words, HD and SD are both MPEG2. What's odd is that it can record widescreen in SD MPEG2 but not DV! I have a DV camcorder that records native widescreen. The other difference is that the SD mode records in progressive scan, whereas the DV is interlaced (again, odd, since other DV camcorders exist that do progressive scan).Originally Posted by BHPhoto
Personally, I would choose the DV over the SD since DV is better suited for editing. (Actually, I wouldn't even use the HD, which should be called HDV. Real HD is different.)John Miller -
I thought SD was simply uncompressed standard definition video..Usually requiring an interface card with SDI connectors to be able to capture the information...
That being said, i was under the impression SD was what broadcast folk to transfer beta to computer with 4:2:2 colour sampling...
And that DV was a compressed version if SD with 4:1:1 sampling...
And that HDV was Mpeg based stream with the same bitrate as DV, to facilitate filesize...
Just a guess though... -
B&H is about as unreliable as they come, for information.
They still think a Canopus DV box is a TBC!
SDI is uncompressed serial digital 4:2:2 normally at 270Mb/s 720x480/576 (SMPTE 259m/c) but other variations exist for sqaure pixel 16:9 and HDTV 16:9.Originally Posted by pijetro
The JVC consumer HD camera will not support SDI in any form.
Here is the spec sheet showing shooting modes
http://www.jvc.com/promotions/grhd1/spec/spec.html
Component analog outputs are
480p / 59.94, 480i / 29.97
720p / 60 fps HD only
1080i / 30 fps
The 1080i output is scaled from 720p, 480p, 480i -
See http://www.jvc.com/promotions/grhd1/unprecedent/s_right.html - scroll down to the table that shows all the formats.
Basically supports what the B&H blurb says.
Still don't get the widescreen only being available on the MPEG2 channel, though.John Miller -
why is smurf baggin on b&h?
I've had no probs with those guysXP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card
is it possible to feel the difference?
By FaisalKhan in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2011, 06:17 -
Difference DV capture?
By Abas-Avara in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 15:17 -
What is the difference between these Taiyo's?
By ha13may in forum MediaReplies: 3Last Post: 27th Sep 2008, 15:01 -
HD-SD Time Difference?
By Nelson37 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2008, 21:13 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 13:59
