Results 1 to 11 of 11
    Sep 2006
    i got a nec dvd +rw burner right now. i really dont have a need for the RW, just the R. i want a dual layer burner. and i dont want to have to worry about the media not being compatable. cause i just purchased tome media and its not compatible even though the media is name brand. can someone reccomend a good burner for me that is under $60. there is a pioneer one that looks pretty good. but i dunno what brands are most reliable. cheaper is better.
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Get the Pioneer DVR-111L or DVR-111D, they are excellent drives.
    He's a liar and a murderer, and I say that with all due respect.
    Pioneer
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    BENQ 1650/1655 or PIONEER 111D as already suggested. The PIONEER 111L isn't available in the USA.
    Sep 2006
    thanks guys
  6. Member CrayonEater's Avatar
    May 2006
    Get the firmware update that bitsets DVD+R though. Maybe one of the other folks know which one to get. That tiny little feature can create (or solve) big problems.
    Jan 2004
    Queens
    BENQ 1650/1655. I believe they are the best.
    Jun 2006
    Before buying a new burner try updating the firmware. I had to update my NEC's so they would recognize some new Fuji's (media code Ritek F1) that i recently bought. Link http://support.necam.com/optical/
    If there isn't a newer firmware there try http://liggydee.cdfreaks.com/page/ Those are hacked firmware but I used the ones for 2500a and 2510 and it works just fine.
  9. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    I've had good luck with older Sony drives, as well as LiteOn.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
    Aug 2006
    A good burner, and up-to-date firmware are certainly essential for success, but having a well-known brand name on the package doesn’t guarantee that discs you bought are a quality product. (I don’t think you mentioned which brand.) They could be your problem, and it wouldn’t hurt to check them out before buying a new burner. I found the Blank DVD Media Quality Guide & FAQ to be very helpful.
    I’ve settled on Verbatim as my brand of choice because it proved to be much more reliable than the others I tried and is often available at local stores for a reduced price. Lots of members here favor Taiyo Yuden, which I have no doubt are also good. I just haven’t tried them because they seem to be sold only through online retailers and I prefer to visit a brick-and-mortar store for most purchases.
  11. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    I've been buying the 100ct spindles of Verbatim -R discs at Sams Club since forever. Every once in a while their stock changes to faster media, I believe they are up to 16x now. Not that it matters though. I always burn everything at 4x anyway. That's as fast as old faithful (my Sony) will go
