from some reason i'm not able to inser hebrew subtitles (in SRT format) into a few VOB files i have extracted from a DVD. i can't load the files with TMPGEnc and i can't convert them to any other format. after they are done i need to burn them as DVD again. any suggestions? i am going nuts over here![]()
Results 1 to 9 of 9
i managed to convert to sup file using subtitle creator however ifoedit did not work for me. i also managed to de-multiplex the files to m2v and ac3 (and wave just in case... so now i might have more options to insert the subtitles? what else to try?
m2v + ac3 + sup is exactly what apps like Muxman or Ifoedit wants.
DVDAuthorGUI should do m2v + ac3 + srt too.
/Mats -
In what way doesn't Muxman/ifoEdit work? have you turned on the subtitles when you play back?
DVDAuthorGUI is as freeware as they come=completely.
/Mats -
as far as i can see i turned on subtitles in both ffdshow and in media player classic. i also tried to play the video in dvd playback software but nothing works. i'm trying dvdauthorgui now maybe that will work.
dvdauthorgui does not even load saying some ocx file is not registered...
Make sure you selected 'full install' when installing DVDAuthorGUI. At the very least, select the 'activex components'.
how to separate subtitle from vob or mkv in srt file
By ashe09 in forum SubtitleReplies: 5Last Post: 10th Oct 2011, 03:38 -
How to watch an mp4 with subtitles in a .srt file
By Robor in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2011, 07:47 -
How to merge .srt subtitles to a .vob video file
By GoNGaXiNHuO in forum SubtitleReplies: 5Last Post: 29th Dec 2010, 08:04 -
Burn .VOB File with .SRT to DVD+R DL (HELP!)
By holdenmcclure in forum Authoring (DVD)Replies: 2Last Post: 8th May 2008, 01:47 -
Subtitles to .srt file ripper?
By vidmarc in forum MacReplies: 1Last Post: 8th Aug 2007, 14:33
