When recording music videos (which are broadcasted in 4/3 letterbox) they often use the upper black stroke for TV-logos and ads for ringtones etc..
What i'm looking for is some tool to black out this part of the picture to obtain a "cleaner" 4/3 letterbox music video.
I saw this done on some videos i downoaded.
You can use something like delogo, logoaway, or region remove, or simply mask the area of the logo. Masking the area is better than cropping, since you don't resize anything.
Thanks for infos, but i think those scripts are a bit complicated for me..
And yes, those logos are popping and moving
But while browsing from yur links i found a really easy solution.
The "add border" function in "DVDcomposer" is really the thing i need..
https://www.videohelp.com/forum/archive/t270977.html
I think i should try that one.. -
Huh? Neither does Crop followed by AddBorders resize anything. The Letterbox command does mask the area in question (but both top and bottom black areas). And both Delogo and LogoAway are slow, inferior, and completely unnecessary if the junk he wants to get rid of is entirely in the black, as he seems to say.
That DVD Composer Add Borders seems to... add black. It says nothing about first removing or covering up the stuff you want to replace. Maybe I read it wrong, though. Still sounds to me like a silly way to do a simple job. And I'll bet it's very slow. So, tell me what's so difficult about:
AVISource("C:\Path\To\MusicVideo.avi",False) #False disables the audio for handling separately
Crop(,0,60,0,0) #or however many lines of pixels have to be removed
AddBorders(0,60,0,0) #replace with fresh black
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 03:12 -
what is the meaning of these ? frame based, lower & upper field first.
By khalid81 in forum EditingReplies: 3Last Post: 15th Jun 2009, 11:27 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 22:54 -
PAL to NTSC -- Upper or Lower field first?
By hurricane1951 in forum EditingReplies: 2Last Post: 1st Aug 2008, 05:39 -
AVCHD - upper fields or lower?
By tat2jr in forum Video ConversionReplies: 8Last Post: 29th Jul 2007, 11:38
