Alright heres the problem. (using ffmpegX v0.0.9w r5)
I have been starting with a movie in wmv3 format, I seperate the 2 streams (VCD and mp3).
While this process errors out at the end, I believe it to be a result of the audio stream being inverted, as the movie itself works just fine.
Then I mux the two streams into a mpeg and convert it to avi.
For the most part, this process results in a file smaller than the original wmv, however check ffmpegx's size button to determine what the approx size should be, I find the final size to be double of what ffmpegX estimates.
So if I recompress/convert the movie to avi (avi->avi) using the exact same settings, the output becomes larger that the original. oddly enough. Figuring that the avi is or maybe corrupt. I use the fix feature under tools. The file becomes 2mb smaller, on average.
Being a patient guy, I repeat the compression process. Doesn't help because the fixing method only works to a certain point.
So is this problem related to movies which started as wmv3? No.
If I try to resize a video or change the bitrate on an avi file (avi->avi). The problem is surfaces again, most of the time.
Usually I use the following settings as most of these videos are for archiving
200Kbs, 480x360, 32kb sound and 32000 sampling.
Any ideas?
How much can a Blu-Ray movie be compressed before noticeable quality loss?
By Rampage Jackson in forum Blu-ray RippingReplies: 19Last Post: 20th Jun 2012, 10:28 -
Sony Vegas Pro mpeg rendering size larger than movie studio
By bbbbbbb45 in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2012, 12:31 -
How we can bring a compressed movie in genuine condition
By nusratjaveid in forum Newbie / General discussionsReplies: 13Last Post: 20th Oct 2010, 21:49 -
Original audio tracks for overdubbed movie
By chasethepony in forum AudioReplies: 5Last Post: 20th Dec 2009, 02:44 -
AutoGK - experiences and problems of ripping a larger movie collection
By vchrizz in forum DVD RippingReplies: 2Last Post: 22nd Sep 2008, 17:43
