Hi,
I have a DivX AVI that I am trying to encode to VCD. The problem is that it is loaded with bad frames. Are there any programs that will go through and fix/remove the bad frames? Or is there an encoder that will skip them rather than crashing?
~dev
try DivFix or get the Panasonic Encoder (it will handle bad frames)
problem is Panasonic doesn't resize so if you have bad frames and you want to resize you have to frame serve from VirtualDub - which might not handle the bad frames too good - so then you have to use AVISynth ...
... it can be a pain in the ass to convert a bad DivX
Hi,
I tried the Panasonic Encoder, but, it either says proper codec not installed, which it is or after only 2 seconds it says encoding done, leaving a zero byte file.
Any thoughts?
~dev -
the only time thats happened to me when useing the panasonic encoder was when i didnt pay for it
so find another version of the prog on www dot cdrsoft dot cc/
Well this is the trial version, downloaded from the official site and not tampered with in any way.
*shrug*
~dev
DivX -> AVI/MPEG - stumped!
By ouroboros10 in forum Video ConversionReplies: 4Last Post: 7th Apr 2009, 13:23 -
DVB-S MPEG -> DivX
By geohei in forum Video ConversionReplies: 8Last Post: 11th Oct 2008, 11:11 -
Firewire to divx/mpeg-4
By exon in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2008, 19:59 -
Divx has subtitles and I want them permanently on an MPEG, but....
By darthvonpokemon in forum SubtitleReplies: 2Last Post: 14th Jun 2008, 11:45 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 14:17
