i have downloaded an movie but it is in three parts and i cant vind another good one so can someone help me whits program i most yous to join them together to ged one movie
heeeeeeeeeeelp
You don't say what format/codec it's in, but look under Tools at left and search for various editing programs. Don't waste your time with those "joining" and "splitting" software - they don't work well, and often not at all.
If it's a AVI type format like Xvid, VirtualDub does a good job of 'Appending' video files together. Joining MPEG is a little harder and the editors like CrayonEater mentioned may be what you need. Cuttermaran is a freeware editor and works well for MPEG.
It also depends how you plan to watch the final video project. If it's on a DVD, then you may not want to join them, but let the DVD authoring program set them to play one after the other.
Joining videos can cause audio/video sync problems at times. That's one reason the format of the video makes a big difference. A program like Gspot 2.60 can tell you a lot about the format.
What programm i can use for editing HD files???
By TonKhaO in forum EditingReplies: 4Last Post: 12th Apr 2009, 01:21 -
Difference between programm and transport stream?
By Lippy Lipstick in forum Newbie / General discussionsReplies: 2Last Post: 15th Dec 2008, 04:50 -
What programm, could take out pieces of video, and exchange them for other
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 25th Oct 2008, 08:28 -
can someone recommend a good and not to hard programm that would do this?
By Remyisme in forum Newbie / General discussionsReplies: 5Last Post: 3rd Sep 2008, 23:03 -
Best DV capture programm
By PeterK in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 28th Sep 2007, 13:55
