Hello,
I 've renamed the title to English and using notepad to script the DirectShow by avisynth to direct the file to virtualDubMod . There is an VitualDob Error message Avisynth Open Failure import cannot open C:/Chinese Movies/ ?????/????.avs. The movie plays on the Media Player Classic.
I've gone through search in VideoHelp and google rmvb and find nothing. Please help.
Thanks![]()
try to change the folder and file names to English. those question mark are chinese right? change it to English.
Superguru,
I tried changing the name of the folder and the file name as well as the title of the movie into English. But no go. I saved the AVISynth script both in ANSI and UNICODE but niether one worked.
Celtic_Druid,
The MPC supports the movie by playing it but it has no conversion capability.
I recalled the AVISynth should support it but I'll check.
Thanks -
Did you happen to install RM Alternative codec to allow Windows Media/Classic player to play RM files ?
Once that has been done, using AVISynth script to transport the video to VirtualDubMOD should be a breeze.
Cheers, -
Hi there,
Thanks, now I can watch RM files but how can I convert them or avi files so I can burn them into DVD. As I understand VirtualDub or VirtualDubMod is for getting the sound in sync. Thinking that it also convert to avi, I tried to dub the movie using VirtualDub-MPED2-1.611. Then I was going to use TMPGENC X-Press to encode it to mpg. It froze and the following error message appeared:
[b]FREEZE LOG DUB I/O THREAD NOT CYCLED 30 SEC. POSSIBLE LIVESTOCK (thread action reading/processing video and audio from current address 7C90EB94 ) Avg. bitrate (kbps ) 761
I have been going at it for months without any success. Please helpmetta
Conversion Question: rmvb file via dvd player
By seifhatem in forum Newbie / General discussionsReplies: 5Last Post: 17th Nov 2010, 11:01 -
rmvb with chinese characters won't play?
By js2k in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2009, 11:39 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
real/rmvb to avi Conversion Unrecognized
By drummachick in forum ffmpegX general discussionReplies: 1Last Post: 15th Feb 2009, 05:56 -
conversion from 2 avi files to a one DVD title in DVD flick
By netimen in forum Video ConversionReplies: 2Last Post: 30th Jun 2007, 09:06
