  1. I'm in the early stages of learning NVE (as well as other authoring alternatives). Could another user straighten me out on a couple of basic points about the Edit Menu section please?
    1. Suppose I open a DVD-Video project I worked on earlier, say Test.nvc. I make a change, maybe the template or the shape of the buttons. How do I save that as a project with a different name? The Save button just overwrites Test.nvc. Is there no 'Save As' facility as you'd expect with any editing program? This seems to mean I can't experiment with alternative layouts. (Unless I manage this outside NVE by making regular copies.)
    2. Suppose I carefully customise the buttons with images from my video. But if I then choose a different template, all those revert back to standard. Is that a bug, a serious design flaw, or my misuse of the GUI?
    Any advice would be much appreciated please.
    Terry, West Sussex, UK
  2. In case it helps anyone else ending up here after a search on a similar query, here's Nero Support's response just received:
    "No it's not possible to save the files to a differnet file name. You can only save the file and rename it, so the next save will not overwrite the first one."
    A significant weakness IMO.
