Able to import into DLP2.
I want to display the chapter's title (static) with a countdown clock. Able to select intervals so lets say display every second of the countdown.
TIA.
The only way to do this is to create a seperate title clip of the selected duration, and create a specific subtitle for that title clip. User selects, for example, a 10 second countdown, and the ten second clip plays. If they select a 5 second countdown, the five second clip plays. Mind you, if you are creating seperate clips, you may as well just put the timer in the clip, rather than use subtitles.
I have seen a few DVD based games that use countdown timers and this is how they do it.
Another method would be a single clip starting at 30 seconds and counting down to zero, with chapter marks at 5 second intervals. Just start at the appropriate chapter to countdown for different periods. Accuracy of chapter points would be the main issue with this approach.Read my blog here.
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 03:09 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Tool for adjustment synchronization of video , audio and subtitle on AVCHD.
By wisitch in forum Video ConversionReplies: 4Last Post: 1st Jun 2010, 04:16 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 14:17
