I got a comment mentioning that the PCM volume of my DVD is lower than the Dolby Digital Settings, is there a way to correct this? and how come this may have happened?
if this is your dvd and you authored it then just bring up the overall volume of the pcm track (from the source files) and re-author. This sounds painfully easy so I'm guessing theres more to your problem than that?
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 20:51 -
Lower volume with Zoom Player
By genegold in forum AudioReplies: 2Last Post: 5th Aug 2009, 01:48 -
Lower volume of mpeg file
By pslates in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 14:57 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 17:54
