Results 1 to 10 of 10
    Jan 2006
    I wanted to see what people consider the "routine" codec set up when setting up a new machine.
    I would need a good codec for both mpg2 and .avi files (encoding & decoding both)
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    there are 55 types of avi files more or less - which do you mean ?
    you will need a mpeg2 codec, an ac3 codec and ffdshow and/or xvid codec, a DV codec ......
    about it for 90% of most people .... really depends what you want to encode and decode
    MPEG-2, AC3, XVID, DV25, QuickTime Alternative, RealMedia Alternative ... that's about it.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    i dont even think you will need realmedia alternative .... ive never needed it --- i just avoid anything related to real media
    Mar 2005
    Toronto
    i just download Community Codec pack. Works for me
    Do not do a codec pack unless you want to re-format and start over again.
    Read https://forum.videohelp.com/viewtopic.php?p=1575175#1575175
  7. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    K-Lite is a pretty decent codec pack.
    http://www.free-codecs.com/download/K_Lite_Codec_Pack.htm
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    edit...wrong thread.
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
  10. Member Skith's Avatar
    Bottom of the ocean
    Despite the name, CCCP (Combined Community Codec Pack) is not actually a codec pack but a set of filters/custom ffdshow build. http://www.cccp-project.net/
    There is even a tool which helps with cleaning up messes left by old installations of other codecs.
    It allows plenty of control over what you want installed, and provides a control panel for easily registering and unregistering specific filters in ffdshow (AAC, AC3, MP3, AVC, divx/xvid, etc...)
    I personaly use it, along with some other codec/filters for playback (mainly CoreAVC Standard and AC3filter). Despite the fact that it seems to have been devolped for the anime fansub community, I have found it to be a good, simple all around solution that provides easy managment of filters.
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
