If I have an Xvid file I want to watch on a DVD/VCD player how do I know whether it would convert better to either VCD or DVD?
I've always converted to VCD assuming just by file size that they're not suitable for DVD conversion but I found a guide here for Xvid to DVD conversion in which the filesize is 700mb - so a film sized Xvid of 700mb is good enough for DVD I assume
(Gspot says the file I'm about to convert is 23.97 fps, bitrate 766 kb/s, 512x384)
For a PAL DVD you can choose from 3 basic resolutions 352X288 (equal to VCD), 352X576 (1/2 DVD) and 704 or 720 X 576 (full DVD). Which resolution is closest to your source? That is what you should be trying to determine when you go to make your DVD. Pick the closest one and make your mpeg to suit, don't bother with VCD. The lowest DVD resolution is basically VCD on a DVD anyway.
I'd use 1/2 DVD for your example which is NTSC, therefore 352X480."Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
Or 704x480 if he wants an NTSC DVD. 352x480 will be noticably less clear than his 512x384 source.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 06:31 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
convert vob files of karaoke to xvid and still maintain the same chapters
By volam in forum Video ConversionReplies: 14Last Post: 14th Jun 2009, 21:50 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 16:51
