Ok, manages to get a working box. Ran the drivers, got a device and CapDVHS appears to capture just fine.
Out of nowhere, a few timed recording end up not being very compliant. Its causing VideoRedo. as well as other mpeg2 apps (Pegasys Encoder, HDTV2Mpeg2, etc) to hang, thus crashing any attempt to edit out commercials.
Any quick fix for this? Or must I re-capture off the DVR and try again?
try running the HDTV files through MPEG2Repair, then try editing. Fixes transport stream (*.ts/*.tp) errors.
I had this happen to me at least once with CapDVHS. VideoReDo's QuickStreamFix will take care of this problem just like TBoneit says.
My experience with freeware solutions such as MPEG2Repair has not been very good, so I'd advise the QuickStreamFix approach since you already have VideoReDo. -
Yeah this problem keeps occuring.
So I have some football games recorded on it, I use Cap-DVHS to time record it, setting the timer for about 3 hours before I leave for work or go to sleep. When I get back, it appears random, some mpeg2 files are editable, some arnt.
I have a feeling that it must be the software. Is there a better program for Firewire capture? I've taken a look at a few, most capture to avi and I need mpeg2.
EDIT: Using VideoRedo's stream fix and the mpeg2repair program do not resolve this problem. So I end up having to re-capture the game a few times before I get one that I can edit.
Capturing HDTV with a Firewire and Capdvhs problems
By superdud1400 in forum DVB / IPTVReplies: 2Last Post: 31st Aug 2008, 02:15 -
Wish to convert from .TS to compliant MPEG2
By gabier in forum Video ConversionReplies: 28Last Post: 9th Jul 2008, 03:34 -
Good Firewire PCI card for Capturing HDTV?
By superdud1400 in forum Capturing and VCRReplies: 1Last Post: 12th Jun 2008, 05:11 -
Recording cable HDTV via firewire
By hipser in forum DVB / IPTVReplies: 3Last Post: 18th Apr 2008, 17:58 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 06:49
