I downloaded a music video from youtube.com, which of course, is in .flv format (flash). I am attempting to convert it to XviD. For those of you reading this that use SUPER, you know that the video bitrate encoding tops off at, i think, 9700. Using a bitrate calculator, i came up with a bitrate of 9982, or something, for the music video. It is only 9 mins. 41 seconds long. How do i configure XviD so that the video gets encoded with a bitrate of 9982, going past the limit of 9700 that SUPER tops off at?
any help would be appreciated!
Chances are that XviD would reach saturation before 9,982kbps anyway. For a video to require a bitrate that high it would need to be high resolution, which I doubt the flv is.
For some perspective, the HT profiles max out at 4,854kbps. -
Forget bitrates. Convert to Xvid in single pass target quantizer mode. Setting the quantizer to 2 will give you a video that's almost indistinguishable from the source, even when looking at enlarged still frames. At 3 there will be a little macroblocking if you look at enlarged still frames but you won't notice them at normal playback speeds.
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 21:05 -
SUPER converter program has Encoding Failure Error
By kerrex_2006 in forum Video ConversionReplies: 4Last Post: 26th Sep 2009, 13:44 -
SUPER - is it really super? (a behind-the-scenes look)
By BaronJT in forum Video ConversionReplies: 5Last Post: 2nd Aug 2009, 08:29 -
Building a super-powerful encoding station (or trying)
By Gargalash in forum ComputerReplies: 28Last Post: 20th Nov 2008, 10:22 -
Video_TS to Divx. super poor quality after encoding
By mistervolcom88 in forum MacReplies: 5Last Post: 13th Sep 2007, 13:49
