  1. hi guyz,
    how do i convert a mpeg format to dvd format?
    can anyone recommend any good programs?
    thx
    USA
    First you need to check if it's DVD complaint. Look to the upper left for 'WHAT IS' DVD. If it's already compliant, then you just need to author it to the DVD structure. If not, you will have to re-encode it first.
    Guides for Re-encoding or encoding are in 'CONVERT' to the left.
    Guides for authoring are in 'AUTHOR', same location.
    Look in 'Tools' for encoders and authoring programs. <<<<<<
