Hi,
I'm a newbie and i need help.
I use Windv to capture avi file from Canon DV . Then , I use TmpgenC to encode avi to mpeg. How do i create a DVD from this file? I would appreciate your help if you could walk me througth the whole process after capturing the dv tape to avi file in computer. I am trying to convert all of my DV tapes into DVD.
thanks.
If your mpeg is DVD compliant, all you need is Authoring software. There are several options available in the tools section. I personally use TDA. It's simple and good, but limited in some ways.
Buy My Books -
Click here for a TDA guide.
Create a streamable mpeg-4 avc in TMPGEnc Xpress?
By KingsCrown in forum Video ConversionReplies: 2Last Post: 22nd Jan 2010, 08:20 -
How to fix MPEG encoded with wrong aspect ratio?
By Talayero in forum Video ConversionReplies: 2Last Post: 21st Oct 2008, 09:29 -
create DVD from MPEG-4 AVC
By unplug in forum Video ConversionReplies: 20Last Post: 12th Aug 2008, 23:51 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 10:22
