I am planning to get AverTV Purity 3D MCE 500 TV tuner. I am interested to know whether it is compulsory to use Windows XP Media Center Edition 2005 to use this card. Or, can I use other Media Center Softwares such as Beyond TV 3 / Sage TV V 5 etc ?
vsenapati
Check the BeyondTV and SageTV sites for listing under hardware encoding suport. I know nothing about either card but what you need is a card that is supported for hardware encoding. If the card is only supported for software rendering, your PC is usless for any other task during PVR use.Originally Posted by vsenapati
Next search the BeyondTV and SageTV user forums to find other's experiences with these cards. Some "supported" cards have pages of user horror stories. -
Yes that card is support in SageTV and BeyondTV it just like the nVidia DualTV, but you my want read this before going buying one.
http://www.htpcnews.com/forums/index.php?showtopic=23900
DVI to Component to AverTV HD Express- YPbPr works on HDTV but not AverTV
By asperi in forum Capturing and VCRReplies: 1Last Post: 9th Jan 2012, 10:22 -
Hauppauge or AverTv??
By markypizz in forum Capturing and VCRReplies: 4Last Post: 11th Jul 2010, 16:28 -
Best PQ as possible via external tuner? Bypassing internal tuner/processor.
By Wizard256 in forum Capturing and VCRReplies: 0Last Post: 24th Jan 2010, 23:39 -
Hauppauge HVR-1600 HD tuner with MCE 2005
By rallynavvie in forum Media Center PC / MediaCentersReplies: 60Last Post: 29th Mar 2008, 14:22 -
High Definition TV? Tuner or no Tuner?
By aturjans in forum DVB / IPTVReplies: 6Last Post: 17th Mar 2008, 08:31
