Hi i have a .DIVX movie it gives me a CRC error when im trying to copy it, but it plays fine on windows media player. Anyone knows what causes this and how to fix it?
thanks!
PD i dunno if I run a Checkdisk and it fixes that it might corrupt the file![]()
What software is telling you there is a crc error?
Google is your Friend -
faramith,
The fact that your avi plays fine is not an indicator that there are no CRC errors. Typcially, all it takes is one bit in one byte to create a crc error. However, one bit within one byte will not be seen in a video.
In normal computer usage CRCs are most generally generated when you "transfer" data from one place to another (i.e, disk to memory, memory to disk, memory to application, or disk, etc). When the receiver does a crc check on the received data stream and it is not the same as what the sender sent you, then normally a CRC error is raised and depending upon the level of sophistication built in either a retransfer happens or processing stops.
Some typical causes are noise on the line (sometimes called burst errors and most CRC algorithms will account for some classes of this type but not large amounts). The sender and reciever not using the same CRC algorithm (rare but it does happen).
So as the previous poster said, under what circumstances did this crc error happen? -
Originally Posted by edsmith77
You could try opening a DOS command Prompt and copy using Xcopy. Xcopy /? will give you all the commands. However /c is the switch to continue copying even if errors occur.
CRC Error on Data File, CHKDSK Fails to Repair, Now What?
By PartingShot in forum ComputerReplies: 6Last Post: 16th Dec 2009, 16:56 -
CRC errors when copying DVDs
By Shadowofthedarkgod in forum Newbie / General discussionsReplies: 7Last Post: 1st May 2009, 02:59 -
CRC Errors when copying to HD
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2009, 06:24 -
Help Cannot Unzip Last File CRC Error
By mn072065 in forum ComputerReplies: 16Last Post: 18th Jul 2007, 09:48 -
damaged file(crc error) how to get it off dvd
By invadar in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 08:59
