by default besweet converts to mpeg 1 layer 3...
what parameters are to be used to convert to mpeg 2 layer 3?
Originally Posted by cL0N31
It makes things much simpler than trying to work out command line options.
And usefully it also shows you exactly what the command line is, so you can cut and paste that if you want to develop your own scripts.
for instance, this is the command it made to convert an AC3 to MP2:
"P:\BeSweet\BeSweet\BeSweet.exe" -core( -input "Q:\02.ac3" -output "Q:\02 - New - [10.09.2006] - [18.53.41].mp2" -logfilea "P:\BeSweet\BeSweet.log" ) -azid( -L -3db ) -ssrc( --rate 48000 ) -toolame( -m s -b 128 -e )
Once you have a working command, you can RTFM and tweak the options if you want.
BeSweet not converting to Stereo
By takearushfan in forum AudioReplies: 9Last Post: 1st Jan 2010, 11:10 -
besweet, belight
By volam in forum AudioReplies: 0Last Post: 9th Sep 2009, 20:53 -
Besweet causing problems?
By hardcorejason in forum Video ConversionReplies: 1Last Post: 27th Apr 2008, 13:59 -
besweet 5.1 wav
By dvdfreak1971 in forum AudioReplies: 1Last Post: 11th Apr 2008, 14:44
