I used AutoGK to transcode DVD to DivX. Well, somehow, someway, the audio is very low on the resulting file. The video looks great. Can someone please suggest some software that will allow me to increase the audio? thanx!
What kind of audio (codec) is it in the AVI?
What kind of audio stream did you select in the source file?
/Mats -
hi. I fixed it! I used a file called Magix Movies on CD & DVD, and they have a way to increase the volume.
thanks anyway for your help!
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 17:59 -
Video Resolution on newly created .wmv - Poor
By whitey218 in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2010, 19:52 -
How can I use an existing motion menu, on a newly created dvd?
By Denvers Dawgs in forum Authoring (DVD)Replies: 13Last Post: 23rd Jun 2009, 16:09 -
no sound with newly downloaded .avi file
By JediPM in forum MacReplies: 7Last Post: 30th Dec 2008, 16:29 -
Audio very low after VIDEO_TS -> DivX conversion
By mistafro in forum ffmpegX general discussionReplies: 7Last Post: 28th Feb 2008, 19:42
