I have several clips already in Xvid format is there a tool that will allow me to add chapterpoints and leave them in Xvid format? Or must I convert them to MPEG2 and add chapters in when I author them to DVD?
The latter.
Or the new DivX container format (not the video codec). Not much player support for this tho.
/Mats -
Or you can split the xvid file into smaller pieces so you can use the next >>| button to advance every, e.g. 10mins or so
Denis -
Depends what you mean by XviD format. A raw XviD stream can't have chapter points. Mux that XviD stream to mp4, mkv, ogm, dsm, etc. and you can have chapter points. Chances are that you meant avi format though in which case the DivX media format as suggested already is as close as you can get.
XviD != avi.
PAL to NTSC Chapter Points
By sambat in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2009, 08:52 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 18:38 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
