I'm having a problem using "ImgBurn". When I read the directions, and used them every Thing went well, but when I put the disc in my DVD Player, it says "Bad Disc" and can't read them. When I use "Nero 6" I have no Problem. I was using "ImgBurn", because it is faster then "Nero". I tried "ImgBurn" a few times, to see if I could solve the problem, by doing different adjustments, but I still get the same results. Can someone, tell me what I am doing wrong? Thanks In Advance...
At a guess I would say that what you are burning is not DVD compliant. Nero will, to some degree, attempt to make your content compatible, (which makes it take a long time), but imgburn just burns what you give it (like a burner should).
Buy My Books
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 20:53 -
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 18:47 -
BD - RE to use with ImgBurn
By fjmr in forum Blu-ray RippingReplies: 7Last Post: 2nd Aug 2009, 22:08 -
USING ImgBURN!
By guitarparth in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 15:20 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 11:05
