  1. Hello
    Tell me with one i should use?
    With one is the best etc... has anyone test this Templates?
    USiT
    Dec 2001
    The templates have all diferent functions and qualitys. I use the VCD(pal)-template. A movie used with this template fits on 2 discs. But remeber i use pal because this is the standard of my country(sweden)..
    The VCD(pal)-template is good for me. Decent sound and pic quality. U can also use SVCD(pal) but the files will be much larger and it will take forever to encode (but the quality is better)..
    Best regards: A.m
  3. The one that is standard in TMPGEnc?
    Im using PAL to im from Sweden my self
  4. I mean the templates on this site
