is it possible to increase the bitrate on a vcd to more than 1150kbps?
Won't be VCD anymore. Instead, clean up your video and your MPG won't need as much bitrate for quality. Of course, I am assuming you are encoding captured video, not a DVD rip. Most DVD rips are clean enough, maybe inverse telecine it to save a few bits (20%?).
Darryl -
Second opinion:
Sure, increase the bitrate, otherwise you need almost perfect source to get good results. Check your player and make sure it can play xVCD which is a higher bitrate, non-standard VCD. Then in TMPGenc, load the VCD template and unlock it. Then, change the bitrate.
I never use the standard bitrate and do most things in the 1500 - 2000 kbps range. Good luck. -
im trying to make a standard vcd because the standalone i have will not except any other hybrid except vcd, and at a bitrate of 1150kbps the film has a lot of blocks, its a dvd rip that iam trying encoding.
hrm....if u must have standard bitrate/resolution
only thing u can do is to set motion search accuracy to high quality (slow) -
fitz15,
what movie is this now?
* ...rip, did you rip it yourself? ...or by someone elses flaud rip?
* R da blocks constant or just in certain scenes?
which plays better:
* anyways, how does it look on your PC monitor?
* and your TV?
I'm trying to find a decent dvd clip to upload on my new storage site
any suggestions on a quicky clip for you to compare???
-vhelp
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33
