Results 1 to 11 of 11
    Oct 2002
    First I was hoping that someone knew of a way to grab the URL for the QT trailer here. I know that lately there are a couple different ways to stop users from saving the files to their drives both involve disabling the right clicking. But usually in the source you can still find the URL. Latly this hasn't been working out so well.
    If someone knows how to get the URL could you please share your method? I would love to be able to do this myself without having to ask the community each time, thank you for you time.
    http://www2.warnerbros.com/happyfeet/videoplay.html?id=Trailer3&type=quicktime&speed=500000
    EDIT: I'm going nuts here, I found the URL's some weird crap with a script who knows I got links
    http://raincloud.warnerbros.com/wbmovies/happyfeet/trailer3/trailer3_500.mov
    http://raincloud.warnerbros.com/wbmovies/happyfeet/babymumbles/babymumbles_hi.mov
    but I still cannot save them.
    When man discovered milk came from cows, what did he THINK he was doing?
    Jan 2006
    Australia
    edit
    Oct 2002
    @drewzor I'm not sure what you mean by edit. Do you mean inside the browser, or when you op en the URL from QuickTime itself?
    @roma_turok Those two trailers are the first 2 on Apple's site, and I do have them, thank you for pointing them out. But the two links I put are two newer ones that aren't located anywhere else. I am trying to put a disc together for a friend. She will love it, if I can get all of the components working together.
    Apr 2004
    Miskatonic U
    drewsor means he wrote a response, then decided, for reasons unknown, to remove it. The videos on the actual happyfeet website are flash video, not quicktime, or at least, not pure quicktime. they certainly don't endt up in the Firefox cache. Even greasemonkey doesn't seem to see them
    Read my blog here.
    Oct 2002
    I did provide the links for the QT, on the Happy Feet page you can select between a few different formats and speeds. You can find that menu if you click "viewing options" on the page.
    In Firefox I can't seem to find where the temp QT files are stored, and in IE (yeah I tried) in the temp folder it only saves the link for the "streaming" versions of the same movie. WAIT (light bulb?!) what if there is no actual downloadable version and they are all in fact streaming is there a program to save those streams QT streams as a permanent file?
  6. Member Sartori's Avatar
    Nov 2002
    Deleted most of detail as Baldrick found an easier (and best) way below I pasted these back in to show how its done manually -
    In essence the direct download path is hidden across a text file and you need to glue it together , then download it and then that will give you the redirector file - change suffix to txt , read it and it`ll give you the real address to download from . Right click the page to view the source (this is a small piece of it , for one of the trailers) -
    var trailer1_path = "http://raincloud.warnerbros.com/wbmovies/happyfeet/";
    var trailer1_id = "happy_feet_teaser";
    For this trailer , take
    and add
    happy_feet_teaser
    and for type of file you want ie mov , real or windows media and speed/bitrate you copy the suffix from lower down in the file -
    so for arguments sake -
    _qt_56.mov
    to give you -
    http://raincloud.warnerbros.com/wbmovies/happyfeet/happy_feet_teaser_qt_56.mov
    Download that and you`ll have a small redirector file , rename its suffix to txt , read it and the url will be inside it .
    <?xml version="1.0"?>
    <?quicktime type="application/x-quicktime-media-link"?>
    <embed
    src="http://pdl.warnerbros.com/wbmovies/happyfeet/happy_feet_teaser_qt_56.mov"
    You can see the url you need above , if your using Net Transport the windows media doesnt need the disecting of the redirector file , it reads it and downloads the wmv file on the fly . The real download isnt working properly , Im short on time to fix it , to see what bit Ive overlooked on it as Id either use WM or MOV anyway .
    I add this back in only to show how its done manually .
    Oct 2002
    Anyone have success with Net Transport cause here I go.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    http://pdl.warnerbros.com/wbmovies/happyfeet/trailer3/trailer3_500.mov
    http://pdl.warnerbros.com/wbmovies/happyfeet/babymumbles/babymumbles_hi.mov
    Right click save as, works fine with firefox here. 23.5MB and 14.2MB.
    I just opened the first .mov links you posted with notepad and found the links in them.
    Oct 2002
    Oh man thank you! You have just made my day. Once again, thank you all for your time.
    Oct 2002
    @Sartori That is a great guide for anyone who needs it (I did) ty. Oh and Net Transport was not the way to go for me but I did get the mov downloaded and converted to mpeg's.
