I searched the forum for reviews of this DVD Recorder but only found a brief discussion of how it differs from DR4. Anyone have this recorder and any thoughts about it? I just bought a Lite-On from Newegg and it will not recognize any of the three types of recommended media I have tried so I'm ready to send it back and try a different recorder. Best Buy and New Egg have sales on the D-RW2). Thanks.
I have the D-RW2... does what it supossed to do. Nothing fancy... no hard drive. I use it mainly to archive suff off my DVR ... football games (GO BUCKEYES!) and races (none of the Nascar crap... ALMS).
When I purchased the unit I was not sure If I had any '-' media at home... mostly I have hundreds of Fuji film '+' that my burner burns the booktype to ROM 8), So I picked up some Sony DVD-r '-' at Best Buy.. sorry I forgot what the ID code was, but they worked perfectly. Last month I invested in some Sony DVD-rw '-' and they also have worked great.
Hope this helps,
JSBIt will be very hard to defend your rights, when you don't have any. -
Thanks for the report, JSB. I ended up buying this since it was cheap at Best Buy and really I only need the machine to do the same kinds of things you discuss (only I'm recording soccer matches from the DirecTV DVR). I will keep using my Cyberhome DVD player for multi-region/PAL DVD viewing. So far I can report that D-RW2 is reliable (I've been using TDK 16X DVD-R), the picture looks good when transferring from DVR and old VHS tapes (although the latter required another VHS machine to re-feed the images to the DVD recorder--see my other post in this forum about interlacing problems), and the machine is easy to use.
Side note:
Does your on/off button have a green light around it... hard to explain.
My looks like it should be lit... like my other Toshiba player does
Originally Posted by JSB1
Daniel
Problem recording with Toshiba D-RW2
By polesel31 in forum DVD & Blu-ray RecordersReplies: 22Last Post: 10th Sep 2011, 20:44 -
Toshiba RD-XV48DTKB
By maggiechow in forum DVD & Blu-ray RecordersReplies: 6Last Post: 24th Oct 2010, 12:29 -
Toshiba RD-XV48DTKB
By GT40 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Aug 2010, 07:36 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 08:59 -
Why is the Toshiba HD-A2 Better Than the HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 15:57
