i have a question on the first screen on the bottom left it gives you the choices
encoding speed
encoding speed (ess)
codec setting
which one do i select?
what is the box under that says
FULL AUTO MODE?
can you suggest any settings for this please?
thanks for your time!
encoding speed means it uses the speed/quality slider to select settings. encoding speed (ess) means the same, but with standalone compatibility enabled. Fact is that for the offical build (unless there has been a silent update), it selects a HT profile in all modes so those two will be the same. In my build, a MTK profile is used for encoding speed, so it should still be compatible with most standalones. Codec settings, means you select your own settings, as I said though a HT profile is still loaded in the official build, so you set 2 bframes, it forces 1. You set a CQM, it forceds H.263, etc.
Which to select? Now you know what they are. You decide.
Full auto? Try it.
problem with fairuse Wizard
By minkz in forum Video ConversionReplies: 4Last Post: 4th Oct 2011, 14:06 -
Fairuse Wizard
By Simmons in forum Video ConversionReplies: 1Last Post: 17th Aug 2011, 18:34 -
Fairuse wizard
By pensioner in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2010, 12:37 -
Fairuse Wizard
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2010, 05:38 -
Another program like Fairuse Wizard?
By glideroggan in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2008, 14:25
