I recently purchased a s video cable and sound cable to run from my computer to my tv.
my desktop is visible.
however when I open Cyberlink (the program I use to view DVD files on the computer)
I can see all the controls on the tv but not the video.
I'm sure I'm just missing something.
Any advice would be appreceated.
Thanks, D
Have a look at this recent thread - it's very similar:
https://forum.videohelp.com/viewtopic.php?p=1572270#1572270John Miller -
Understand "overlay". Read the section in your graphics card manual.
Small world, my sons name is John Miller.
I did get the video to work, Thanks.
My next task is getting color as the picture is B&W.
I've seen a few articals but nothing that helped.
Thanks, D -
Does the desktop appear in color on the TV or is everything B&W?Originally Posted by rezzleJohn Miller
the desktop is color, the tv b&w.
funny thing is when I started this I was using a dvi to hdmi cable and the tv was color.
however I switched to s-video cable and lost color.
I exchanged the dvi cable because the cost of an s-video cable is about 1/4 the cost. -
Color problems with SVideo + TV are often misconfigured PAL/NTSC settings - check the advanced options in your video settings
Trev -
1/4 the cost and poorer quality picture with SVideo vs HDMI and the headaches. Is it really worth it? IMHO if it works I don't fiddle just to save a few bucks.
Question, How long is the Svideo cable? Is it a good quality cable or a low cost cable that can cause signal problems?
One other thing I would look for a DVI to HDMI setup if you go back to that that has a place to connect to audio at the DVI end and not have to run a audio cable to the TV.
I know on my TV that I can sure see the difference if I do a AB comparison between SVideo and Component for example. That is feeding the TV from a Pioneer DVD recorder that has Component or Svideo or Composite.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:16 -
Computer Guys Braggin' Time: What have you built that AIN'T a computer?
By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 15:19 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 12:06 -
Capturing Halo 3 gameplay from computer monitor to computer
By Jamo in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 00:06
