I get a steady trickle of emails from zdnet about their 'latest' downloads... was thinking I should get the oil changed on my Registry soon, but when I went there to find one, my old favorites were buried in a couple dozen newerfangled trial versions- some coming in at 9 megs!
Anybody got a real good reason to pick a particular one these days?
Regarding vid work, anything you'd do special by way of tuneup?
Search for Zangalist. He tested a dozen different ones.
Read that NONE of the famous one do ****. Most of them seem to pick up problems at random. Run it once, fix all the problems, and run it again, and it'll find MORE problems. -
Thanks KS- mebbe someday we'll get a real OS; one that can fix itself without downloads!:]
I usually run CCleaner for registry cleanup. You may have to run the registry cleaner a couple times to get everything but after it fixes the problem and then fixes the problems that fixing the problems caused then it doesn't keep finding thing randomly.
From Zangalist: Easy cleaner,and it's free.JV16 power tools,not free but more than a registry cleaner,and worth the money.I have both.
bmiller,ont.canada
best tv streaming & download sites/services to subscribe?
By wundahoss in forum Video Streaming DownloadingReplies: 0Last Post: 1st Jul 2009, 20:28 -
Upgraded to IE7 & WMP11, now videos download instead of stream
By DVantrease in forum Newbie / General discussionsReplies: 6Last Post: 15th Jan 2008, 15:43 -
Whats the best software uninstaller & registry cleaner ?
By mol3000 in forum ComputerReplies: 5Last Post: 2nd Oct 2007, 03:03 -
Sound & Vision Home Theatre TuneUp
By rico1 in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2007, 14:03
