    Apr 2005
    Rio Grande - Porto Alegre - RS - Brasil
    I'm capturing a 1995 VHS, not homemade (but the problem occurs on homemade tapes too), and I'm having this problem on some frames.
    Like this
    Then, on the next frame
    And it keeps like this. Sometimes two frames in a row have this problem, sometimes more, it's not a fixed number of frames.
    I'm using a Hauppauge PVR 500 and WinTV to capture.
    I believe the problem is my VCR heads, as I use the VCR as a tunner too but I don't have this problem when capturing TV footage.
    Any idea?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I would expect it to be the VCR, heads or playback circuitry. You could try a different VCR just to verify the cause.
    Google is your Friend
    May 2001
    It's either the original tape or your recording setup. If was the head, the issues would be left to right.
    It might be a telecining artifact, but there isn't enough detail to make this determination, and they also generally run left to right (not upper-right to lower-left). Load the video up using VirtualDub and step through the areas where this occurs. Tell us what the results are.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
