    Nov 2005
    Hi
    I captured some live video streaming using my download manager Reget, is was an MMS live stream of an air show.
    I now have a 9 Gig file with no extention, Windows media player and VideoLan both play the file but I have no bar to drag so that I can go to a certain point in the video, I assume its because its a streamed file.
    How can I convert this streamed file to a WMV or MPEG file so that I can jump to a section.
    The video is stream 1
    Codec: WMV3
    Resolution: 384 x 244
    Codec Name: Windows Media Video 9
    Regards, Dave
  2. 1. Make a copy of this file and change the new file's extension to wmv.
    2. Start TMPGenc, and browse to the wmv file, select a TMPGenc template.
    3. Click setting, and then video tab, change the H and V size to one of the nearest choices.
    4. Click start.
    5. Get your mpeg file.
    Nov 2005
    Hi & Thanks
    I have tried what you suggested but that did not work it could not read the video file?
    Re Dave
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Load it in WMM and export as DV AVI, then process it as any AVI to ??? project?
    /Mats
  5. Member Sartori's Avatar
    Nov 2002
    A friend with a fast connection captured a 8hour stream for me and I ended up in the same boat as you , in the end I connected it to my dvd recorder and converted it that way . For some reason really big streamed videos dont like editing , their format is different as I recall from standard wmv files , as standard WMV files can have markers placed in them but mine wouldnt accept them .
    As I recall , I also gave up on converting as the test pieces I did convert , ended up severely out of sync .
