what is the "Win+E hotkey"
Results 31 to 60 of 61
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
Win+E==Opens up My Computer/Windows Explorer on WinXP
Well I have uploaded a new version (1.2) - hopefully the Win+E issue is addressed (can't say for sure as it was not an issue for me... Can KiwiKid confirm?). Also added a couple of new switches for ImgBurn 2.1
All OK now. Thanks for help and effort to produce this handy addon.
No problem - thanks for the heads-up.
I just wanted to say thanks again for making this. I've used it and it works great.
could you add the functionality to burn data DVD?
for example, when you right click on "Video_TS" you will get option to burn DVD-Video. If you right click any other folder, such as "My Data" it will just burn a dvd data disc.
is this hard?
thanks for the proggy!!!!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
I have to say that I have no plans to do this. The idea behind the shell ext is to intelligently only do VIDEO_TS folders. To do what you want doesn't need a shell extension - a simple registry entry would do.Originally Posted by ron spencerSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Correct.Originally Posted by DonnyQuixoteSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Sounds good to me. Thank you ChrissyBoy. I'll try it when I get home from work.
Thank you. -
DonnyQuixote wrote:
Let' see if I understand everything. I can now use ImgBurn to burn all my iso, img, and
video_TS files? I do not have to use Nero anymore? Is this correct? Or have I missed
something. Thank you.
CB wrote,Correct.
Is "Correct" the answear to Imgburn burning iso,img and TS files on the right click extension as if that is the case i do not have it ???.
I only have it when i click on a TS folder so i assume "Correct" means starting up the Imgburn programe and then being able to burn iso & img from there.
Would be nice if you could right click on the iso,img like you can on the TS.
Please advise cheers ian. -
You get .ISO when you install ImgBurn:
The Ext here adds Video_Ts. So what i meant was that with what you get off the shelf and with this extension the post was correct.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Something like:
key:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Folder\shell\B urn folder with ImgBurn\command
value:
"C:\Program\ImgBurn\ImgBurn.exe" /MODE ISOBUILD /BUILDMODE DEVICE /FILESYSTEM "UDF" /SRC "%1"
Other CLI switches may be useful to you. See the text file in the imgburn folder.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I hate to go off topic but I'm hoping ChrissyBoy couild point me where look in the registry. Something isn't quite right in wherever the right click settings are stored. Sometimes a right click takes a long time and othertimes it is quick for the same file.
Thanks -
What are you looking for?Originally Posted by TBoneitSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I think what I'm looking for is to see what handlers are used when I right click a file if I'm being clear. I'm guessing they are in registry entries? Sometimes the list pops right up other times it takes a couple of seconds. Not a lifetime to be sure but it seems to me it should be consistent.
Many Thanks
Silly question but what is 20GBP in US dollars? -
ok. For this shell extension the registry enties are at:
HKEY_CLASSES_ROOT\CLSID\{FDDA5559-1B27-45E0-A4D7-5171E3700C14}
HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandle rs\ImgBurnDVDVideo
HKEY_LOCAL_MACHINE\SOFTWARE\Badger I.T.\ImgBurnDVDVideo\Burn with ImgBurn
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{FDDA555 9-1B27-45E0-A4D7-5171E3700C14}
I don't see that there is anything for the end user to do with those keys however...SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I guess from looking at that the US dollar isn't very strong right now. When did it changer from pounds to GBP?
Thanks for the link. -
I've been using the build mode on single-layer media lately. Good job L-UK!, it works nicely.
They are one and the same...When did it changer from pounds to GBP?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
ChrissyBoy,
Please see the thread below. Is there anyway you can unload your dll from memory after burning so the video_ts folder can be deleted? I am using v1.2 of your Imgburn DVDVideo Shell Ext.
http://forum.imgburn.com/index.php?showtopic=2400
Thanks,
Kizer -
On the case.
I can't replicate this issue at this end and the code looks ok.... Anyone else had this issue with the shell ext?
Everything seems to be ok now, I apologize for any inconvenience I may have caused.
Thanks,
Kizer -
ok. good news.
IMGBURN shell ext query
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 22nd Nov 2010, 11:21 -
IMGBURN shell ext - not working with Win 7 64bit?
By CBC in forum SVCD2DVD & VOB2MPGReplies: 19Last Post: 23rd Aug 2010, 19:11 -
How do make a DVD video disc with an .avi file with ImgBurn?
By DaneClark in forum Authoring (DVD)Replies: 4Last Post: 3rd Jul 2010, 03:08 -
ImgBurn DVD-Video Shell Ext v1.2 & Vista
By guidorobben in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 29th Sep 2007, 16:47 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 11:05
