Used Virtualdub to split an avi into 3 to burn to CDs to play in the dreaded Philips DVP642.
The first and third segments play fine. The second tries to load, then I get "Reading Index", then just back to the menu. AVICODEC tells me:
Video : 484 MB, 1260 Kbps, 30.0 fps, 720*480 (4:3), DX50 = DivXNetworks Divx v5, Supported
Audio : 86 MB, 224 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
Any suggestions?
Have you tried burning another copy of the 2nd disc?
Since 2 of the 3 files play fine and they are all encoded the same, I wouldn't expect there to be an issue with the video/audio specs. My guess would be a bad burn/disc or possibly an issue with whatever software was used to split the file into segments.Google is your Friend -
http://www.jarnot.com/twiki/bin/view/Public/DVP642LisaBsAVIGuide
Also could be an incomplete file -- the index is at the end of the file. DivFix can rebuild the index. -
Also, with the cost of DVD burners and discs as low as they are, you could switch to DVD and save yourself a LOT of time and trouble.
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
How to apply a filter to just a part of the movie with VirtualDub
By Drakul in forum EditingReplies: 5Last Post: 19th Sep 2008, 17:08 -
any media player can play an unpoined part of an avi file without error msg
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2008, 01:58
