I have several movies on dvd`s some have 2 and some 3 on a dvd as lots are short clips as well is there a program where when you insert dvd in drive which then can read all of dvd titles on the dvd and give you a readout which you can then list so there-fore instead of typing all this manually
No, because the titles are only identifed as title one, title two etc. There is nothing in the DVD structure to identify title one as 'Holiday in Rome", title two as "Honeymoon Highlights" etc. There are a number of cataloging tools that can use barcode references to find details for commercial discs, but that's about it.
Read my blog here.
Yeah, I just meant make menus with your authoring software.
The problem comes when you make a DVD-compatible disc, where the files must be named according to DVD standards ( VTS_01_0.VOB etc etc). So simply obtaining a file listing isn't very helpful.If in doubt, Google it.
DVD/DivX Video Cataloguing software..
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2010, 20:37 -
900min in 1 DVD? Several hours/DVD? Multiple movies or tv-series/DVD?
By edvashas in forum Video ConversionReplies: 17Last Post: 29th Sep 2009, 04:16 -
Getting movies onto a DVD
By rodeman in forum MacReplies: 3Last Post: 25th Jan 2009, 18:54 -
Video Cataloguing Software?
By kidburla in forum Newbie / General discussionsReplies: 2Last Post: 5th Aug 2008, 09:05 -
1h40min movies became 50min movies after conversion
By oediv in forum ffmpegX general discussionReplies: 1Last Post: 31st Jul 2007, 15:13
