Can anyone please tell me how to disable the TVGOS on this machine? Is it even possible? My TVGOS never loads, or if it does, it loses it's data every other day, so I only use manual timer recordings anyway. I want it disabled so I don't have to deal with the TVGOS constantly making that seeking noise and changing channels when the machine is off. Can anyone help, please?
There is a thread on this subject in the DVD recorders forum at AVS forum. Look for a thread heading that includes the word Eureka.
If you replace its hard drive with another ( requires a special remote and service dvd disk ) and do not copy what is on the original to the new hard drive, it will not have that function any more.
I have been trying to copy that file from my working original Pioneer hard drive so that it can be made available to anyone who has had a drive go bad so they can restore that function should they want it. It needs to done under a Linux operating system so this has not been easy. -
Thanks for the replies. I'll check out AVS, frobozz.
As for replacing the drive, bit more then I'd like to get into, but thank you trhouse for the comment. A shame they can't update the firmware so it allows the option not to use the TVGOS anymore. That'd be great. -
Just was over at AVS and it seems Pioneer has offered to exhange the old model with the problematic TVGOS for a new model that no longer has the TVGOS. That really seems too good to be true. Anyone here try and have any luck?
Pioneer DVR-531 TV Guide won't come up
By MCnDaHouse in forum DVD & Blu-ray RecordersReplies: 11Last Post: 4th Aug 2008, 21:17 -
TVGOS diagnostics for Sony HX900???
By BayGuy in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Apr 2008, 13:16 -
Pioneer DVR-531 TVGOS menu won't even come up anymore/can't manual record
By ibhay in forum DVD & Blu-ray RecordersReplies: 1Last Post: 24th Jun 2007, 19:34 -
Who has purchased the Pioneer 531?
By ann coates in forum DVD & Blu-ray RecordersReplies: 67Last Post: 17th Jun 2007, 11:56 -
How can I access files from pioneer 531 hard drive using computer
By hlg1111 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th May 2007, 01:08
