  1. 1) Is there any way to burn an image of your movie so it does not need to be encoded each time you burn? (I have 25 copies to make for my team, so the quicker the better!)
    2) When putting background music into the dvd menu, is there any way to loop it to play repeatedly?
    3) With different songs added to my movie, some are louder than others, is there any way to level them to be the same volume?
    4) When i close magix, it saves my movie but not any of my menu, is this normal?
    Any help would be appreciated!!!
    Thank you!
    Oct 2005
    Here & there
    I'm no expert in this program. In fact I have only use it like 6 or 7 times. There is a guy who is the guru in this program . I used to have a link to his web site but I lost it. If I find it I will post it.
    In short, in order to solve question #1 what you need to do is to make an ISO image of the disk..I haven't seen a make ISO from the burn option but you can use a separate program lto make one like Nero or better yet Dvdecrypter ( free and a must have to everyone in my opinion).
    Here is how, Make the 1st disk to your liking. Ones your satisfied with the result. Use the program you prefere to make an ISO image ( an exact foto copy of your disk in a file ) Then use that same program to mass burn that image, the ammount of disk is up to you and each will be exacly the same as the original. Look for guides of how to make and burn ISOs.
    Question #2 I don't see that option there. This program to my opinion is a great editor. It have some other options like capturing, authoring and even burning but these are not its strong points they added this on basic forms. To do what you want edit your video with movie edit, then author with Dvdauthorgui or guifordvdauthor both are free and have many more options. Then burn with Decrypter or Nero.
    Question #3 When you import a song or any audio file you will see a green bar at the left hand side ( time line mode , press tab botton within the program to swich between time line and storyboard). If not use the build in mixer.
    Question #4 No Idea there. But if you learn to do each step separatly you will not have this problem because it will be you the one manipulating the progress of you project.
    Good Luck.....
    I want to believe....
