Hi,
I have some streamed wmv files from tv channel websites which broadcast live content.
Unfortunately tose are are quity crappy quality (320*240 resulotion).
I'd like to try to put them on dvd resolution (lowest one 352*288).
What filters (virtualdub or avisynth) do you recommend me to get the best quality from those files ?
I know I can't expect full quality but if there are some filters that can improve the quality...
Lanczos - but you can't improve quality - only degarde it less.
/Mats -
Ok thanks.
There is no other filters than can smooth or sharpen the picture without increase the seeing of macroblocks ?? -
I tried transition once and got good results.
See if you upsize the video it gets all blocky.
But with transitions you can convert it to HD resolution. Now it doesnt increase the quality but the video still remains the same. You cannot see any extra details but the resolutions is bigger.
I think that is fair enought.
After that you will have to convert it back to dvd or vcd resolution using any other program
If you really have the time is suggest doing this you can increase the size and you get the same quality.
How would you improve the quality of this video?
By choobies in forum Newbie / General discussionsReplies: 0Last Post: 28th Nov 2011, 12:24 -
How to improve the quality of the video
By kemo1000 in forum Video Streaming DownloadingReplies: 2Last Post: 24th Apr 2011, 15:36 -
resize and improve the quality
By SB4 in forum RestorationReplies: 2Last Post: 24th Nov 2010, 14:37 -
What can I do to improve my quality?
By Captain Satellite in forum RestorationReplies: 12Last Post: 27th May 2009, 11:06 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38
