I suddenly noticed that there's NO any SOUND on Flash Player animations/videos,example on YouTube. So i first tried very basic things; clean cache and restart browser,but there was no any affect. Then i started to search info about this problem with Google and found this page: http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=44&catid=184&thre...read=y#4209759
I found solution there. Somehow there was missing values on my [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32] reg. key. I added "wavemapper" value and after that sound was back on Flashes. I also had to add "midimapper",because Midi device was missing on Control Panel audio settings.
http://i6.tinypic.com/2h6wyzb.jpg
I installed earlier today new version of FFDShow,can it caused the problem?
Hi,Originally Posted by Digiface
"can it caused the problem"
short answer yes... but there can be several other reasons...
In many cases.... programs running in the background can conflict with a installationof a program and cause registry to get corrupted and/or files/folder not properlly installed!!
there a golden rule when in stalling programs!!...
1. always disable programs running in the background...!! generally your software install instructions will also say this... especially disable things like firewalls, screen savers, malware scanners, etc!!!
2. a lesser rule , defrag your system before installating software
3. another lesser rule.... is create restore point before instllaing software!! just in case the install goes real bad...!!!
Strange Audio Problem
By Wanderlustus in forum ComputerReplies: 4Last Post: 21st Feb 2011, 14:27 -
Strange MKV audio problem
By Captain315 in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st Dec 2010, 22:00 -
Strange audio sync problem with downloaded AVI
By embreeb in forum AudioReplies: 9Last Post: 9th Dec 2008, 08:30 -
synching m2v and wav audio - strange problem
By ecc in forum EditingReplies: 7Last Post: 20th Feb 2008, 05:22 -
Strange Audio Sync Problem
By innovyse in forum Video ConversionReplies: 2Last Post: 6th Dec 2007, 13:36
